Paraig_Whelan_3
Jan 26, 2018Configure tcp monitor port
I am using the Powershell f5-ltm module to create tcp monitors using the "New-HealthMonitor" function. The default "Alias Service Port" is "* All Ports". As this is not a parameter which can be passed into the Powershell function, what is the best way to configure the "Alias Service Port" after creation of the monitor?
Thanks!
- jaikumar_f5
Noctilucent
I don't know about the powershell, but if its created and you require to modify it, use the CLI or the GUI, the below is the CLI way,
(cfg-sync Standalone)(Active)(/Common)(tmos) create ltm monitor tcp test1 (cfg-sync Standalone)(Active)(/Common)(tmos) list ltm monitor tcp test1 ltm monitor tcp test1 { defaults-from tcp destination *:* interval 5 ip-dscp 0 recv none recv-disable none send none time-until-up 0 timeout 16 } (cfg-sync Standalone)(Active)(/Common)(tmos) modify ltm monitor tcp test1 destination *:8080 (cfg-sync Standalone)(Active)(/Common)(tmos) list ltm monitor tcp test1 ltm monitor tcp test1 { defaults-from tcp destination *:webcache interval 5 ip-dscp 0 recv none recv-disable none send none time-until-up 0 timeout 16 } (cfg-sync Standalone)(Active)(/Common)(tmos)
