Configuration problem in different networks
Hello Folks,
I have installed BIG-IP on my VMware Player and whenever I go to college or at my friends place I need to change the IP address, Subnet mask, and Default gateway which takes enough time to reconfigure it again. So is there any way I can avoid these types of issues??
Also, if suppose my machine has IP address 150.156.22.44 and the SM is 255.255.240.0 then do I need to put the same SM in the configuration utility?
Thanks in advance.
you should be able put the management interface in a subnet without DHCP and just connect to that from your host system. look in vmware player network settings.
