ChrisMaKi_15830's avatar
ChrisMaKi_15830
Oct 14, 2008
Config Sync problem
Hello there,
First of all, great forum! The irules tips have helped me a great deal over the last months!
got a slight problem with 2 Big-IP 6400's that do not want to sync.
I would like to push my config from the active to the passive box.
Now the passive 6400 has a newer config than the active one (not intentionally!)
When performing a sync from the gui or from the cli, I get the following message:
[root@big-ip1:Active] config bigpipe config sync all
Saving active configuration...
Configsync Mode: Push
Transferring UCS to peer...
Installing UCS on peer...
SOAPException: 'Unexpected return Content-Type: text/html; charset=iso-8859-1'
Transport and install failed
Error running config sync all.
BIGpipe parsing error:
01110001:3: Error running config sync all
Both boxes have the same hardware and used to sync just fine.
Any sort of infos welcome.
Maybe there is some king of debug mode that writes the error to a log file?
Thanx
Chris
