renato_76505
Sep 01, 2009complex snat configuration help needed
Hi all,
I've made a drawing of what I intend to do (in attach). My issue description allways refers to that image. I am using a Linkk controller with version 10.0.1
Basically, on the lower third of the image I represent the Clients IPs, on the middle, the f5 the the intended NATs and on the upper third the ISPs.
What I need to do is perform three kinds of source NATs depending on the source IP of the client:
1. Dynamic source NAT
2. Static SNAT -> 1 to 1 relationship
3. Dynamic source NAT with strict port preservation
Thanks,
Renato Barros
- hoolio
Hi Renato,
You should be able to create a list of client IP addresses/subnets in a datagroup with the corresponding SNAT IP address to use. You can check the client IP address against the class in the CLIENT_ACCEPTED event.
If you can use a separate datagroup for each SNAT address, you could use matchclass ( - renato_76505
Thank you for your reply.
Are you suggesting to create a Vserver IP forwarding , with an i rule that applies different SNATs according to the IP of the client?
The problem with this is that, I need to apply different NAT's not only based on the client IP but also on the next hop (which is calculated by the link controller)...
For example (take a look at the picture), the client 10.12.112.1 gets a different kind of NAT (dynamic NAT or basic NAT) depending on which next hop is chosen (192.168.24.206 or 192.168.34.206)...
Thank you,
