Muhammad_Bilal_'s avatar
Muhammad_Bilal_
Mar 23, 2018
command line help on LTM
I need help with command line for our F5 LTM. I am working on a project where I need to create a user in F5 LTM who only logs in, change passwords of other users and save it - that's all. That user should not be able to run any other command Can I achieve it through GUI. If not can this be done on command line. if through command line, need to know the commands Thank you!
