Command for disabling http access for management
I am trying to figure out the correct command for disabling or removing http management access. I believe the following is correct but not sure. This is for version 9-10
b httpd allow "NONE"
Hi!
Have you tried this article?
http://support.f5.com/kb/en-us/solutions/public/13000/300/sol13309.html
/Patrik
- What_Lies_Bene1
Note that I don't think this applies to the iControl SOAP and REST interfaces. If you want to disable everything you may need to consider shutting down the httpd and tomcat daemons on start-up.
- What_Lies_Bene1
If you don't mind about the iControl stuff your suggestion is valid I would have thought. I've no option to test right now but using a tmsh command try this and see if there is a None option;
[tmsh] modify sys httpd allow replace-all-with ... - nitass_89166
Noctilucent
let me test it for you. 😉
root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) modify sys httpd allow none root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) list sys httpd allow sys httpd { allow none } root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) list sys db service.httpd.allow sys db service.httpd.allow { value "" }- What_Lies_Bene1
Thanks as always! - J_48024
How to add multiple IP address range?
- nitass
Employee
- itspec_166936
Thanks much for all your help
