David_Carlin_20's avatar
David_Carlin_20
Mar 29, 2011
Collecting POST binary data not working
Does the HTTP::collect or HTTP::payload not work with binary data? I have been trying to use these while uploading an image (jpg) and it doesn't really work.
Is there another function I should be using?
  • Hi David,
    Did you take a look at TCP::collect and payload?
    Here is a link for that
    http://devcentral.f5.com/wiki/default.aspx/iRules/TCP__payload.html
    I hope this helps,
    Bhattman
  • Hi David,
    I hope this helps,
    Bhattman
