code version not correctly reflected in Device Management
Hello,
Just recently applied HF8 to HA 11code F5s. The correct code and hotfix are definitely being used:
:Active:In Sync] config tmsh show sys ver
Sys::Version Main Package Product BIG-IP Version 11.5.1 Build 8.0.175 Edition Hotfix HF8 Date Mon Feb 9 00:49:11 PST 2015
:Standby:In Sync] config tmsh show sys ver
In the the GUI, under Device Management > Devices the Standby shows both devices running on the correct 11.5.1 HF8. However, the Active device shows itself as 11.5.1 HF8 but shows the standby device as 11.4.1.
I'm getting the feeling that it's still reading what's on the Inactive partition (which is 11.4.1).
Is there a way I can correct this so that the correct code and hotfix is reflected properly?
- dragonflymr
Hi, Did you try (if possible) to force offline Active and then go back?
Piotr
Resetting Device trust has helped me in similar cases.
I believe it is a known issue that isn't always correctly shown. the work around of resetting device trust helps, but is it worth it?
