myabe_230403
Dec 03, 2015CLIENT_SIDE_CURRENT_CONNECTIONS greater than CLIENT_SIDE_MAX_CONNECTIONS
Hello,
I am using the SOAP API to get some network data. I noticed that very often I get the number of current connections (CLIENT_SIDE_CURRENT_CONNECTIONS) greater than the number of max connec...
myabe_230403
Dec 08, 2015I am not sure what you mean by High and low. To get this data, I used SOAP APIS: module => 'System', interface => 'Statistics', method => 'get_global_statistics'. I have used this perl library https://metacpan.org/pod/BigIP::iControl to read this data. All the remaining information seem to be correct (I checked with the values on the dashboard of the load balancer). Your help is very much appreciated!
