myabe_230403
Dec 03, 2015CLIENT_SIDE_CURRENT_CONNECTIONS greater than CLIENT_SIDE_MAX_CONNECTIONS
Hello,
I am using the SOAP API to get some network data. I noticed that very often I get the number of current connections (CLIENT_SIDE_CURRENT_CONNECTIONS) greater than the number of max connec...
mhite_60883
Cirrocumulus
Dec 08, 2015You've done the necessary conversions of the "high" and "low" 32 integers in the SOAP responses into the 64 bit integer that you're actually after?
