edmonaft_351139
Mar 12, 2018Clickjacking protection (X-FRAME-OPTIONS) on F5 LTM 12.1.2 HF2 without using iRules
Hi there,
I wonder if is there a setting that controls this within F5 and hopefully without resorting to using irules.
Thank you!
- nathe
Cirrocumulus
ASM has a Clickjacking feature but there isn't a core feature in LTM to provide this protection. If you don't want to use an iRule then you can create a Local Traffic Policy, something like this:
ltm policy /Common/clickjacking { controls { response-adaptation } requires { http } rules { x-frame-options_rule { actions { 0 { http-header response insert name X-Frame-Options value DENY } } ordinal 1 } } strategy /Common/first-match }You may want to enable this on specific URLs.
Anyway, hope this helps,
N
