CLI relicense for another add-on to existing base and add-on
Hi there, i'm trying to relicense my big-ip which has an existing base and add-on module. but now i want to apply another add-on module to those two. i've looked at the tech note for relicensing by using the cli:
https://support.f5.com/kb/en-us/solutions/public/2000/500/sol2595.html
however it doesn't seem to cover this case. does anyone know what the right steps or how to add another add-on license to an existing base and add-on? thanks!
- nitass
Employee
have you tried -a option?
[root@ve11a:Active:In Sync] config get_dossier usage: get_dossier -b "basekey1,basekey2,..." -a "actkey1,actkey2,..." -i "inactkey1,inactkey2,..." [ -k ] [ -v " "] - mhuss3y_61750
Thanks nitass. I havent trief yet as i was concerned about the tech note comment: " When re-activating any existing license (including a license with an add-on registration key), specify only the base registration key in the get_dossier command."
In my case should i specify both my existing base + add-on + new add-on with the get_dossier command?
- nitass
Employee
i think it means license which includes add-on key (add-on key is embedded in base registration key).
i think so.
