fubarSUSHI's avatar
fubarSUSHI
May 02, 2020
cli preference display-threshold 0 for all users
Im trying to find a way to modify tmsh cli preference display-threshold 0 for all users. If I run it on my user account or even root... it only modifies it for the given user account. Is there a way to make this a global command for all users?
  • never done anything with it, but looking at this you might get somewhere with changing the /config/bigip_user.conf file :
    https://devcentral.f5.com/s/question/0D51T00006i7hIMSAY/is-cli-preference-setting-for-a-userspecific-setting
    do test this well before trying in production.
    • jaikumar_f5's avatar
      jaikumar_f5
      Icon for Noctilucent rankNoctilucent
      Well provided the users are not TACACS based, because I think bigip_users.conf would come into picture only for LDAP users.
      Also if the users are from LDAP, then he would manually require to put entry for every users as cli preference and load the files later, which would need to go under planned maintenance window.
      • boneyard's avatar
        boneyard
        Icon for MVP rankMVP
        not sure about the TACACS part and certainly not the perfect solution.
        but im not aware of anything better, perhaps someone else.
