epaalx's avatar
epaalx
Icon for Cirrus rankCirrus
Feb 22, 2017
Clarification of "TCP CSYN" and "UDP CS" in TMSH Reference
In TMSH documentation associated with
/ltm profile fastl4
's
pva-offload-state
attribute, the text refers to "TCP CSYN" and "UDP CS". What are these two terms?
  • can you just show the full text you get?
    mine says
    pva-offload-state           Specifies at what stage the ePVA performs hardware offload. embryonic implies TCP SYN or first UDP packet, establish implies 3WAY handshaking or CS round trip confirmed.
    so i see no TCP CSYN, but regular SYN.
    i do see CS, which might be Client Side. in any case i assume it means it will only be offloaded if there has been a UDP response.
