Citrix Xanapp webtop issue
Dear all i am using f5 LTM for citrix xenapp. To deploy xenApp i used teplate provided by F5.
Now clients from the outside network able to access loging page and the can login with there User ID and Password.
When the are clicking on XenApp webtop they are geting the error:
Unable to launch your application. contect your help desk with the following information. Can not connect to the Citrix XenApp server. There is no citrix xenapp server is configured on the specified ip address.
Please help me with this.
- DeepakK_154002
Someone please tell me which ip address is asking about & where i did mistake? - Matt_Dierick
Employee
Hi, if you have LTM only, it's normal. LTM does not proxy ICA protocol.
So ICA file received by the receiver, is proposing a local/internal IP address. You have to add APM module in order to support ICA proxy. This module will add SSLProxyHost parameter in ICA file.
Else, have a look here : https://devcentral.f5.com/questions/irule-required-to-change-citrix-ica-ip-address
- DeepakK_154002
HI Matthieu Dierick thanks for your help. It seems i have to use APM.
APM is the way to go but for now I have opted to use the CSG as the ICA proxy. So essentially my Web Interface VS has the CSG as a pool member. I also had to enable SSL passthrough.
Would you please tell me what is CSG here. if its working for them then it should work for me as well. Please help
- DeepakK_154002
And if the APM is the only way please tell me how can i do that with APM.
- Matt_Dierick
Employee
If you want to use CSG, you have to set CSG in order to proxy ICA from public access (I don't remember the gateway mode to use). That's means CSG has to know the public FQDN and patch ICA for that. CSG reads HTTP headers in order to know that. You can keep LTM in front of CSG.
With APM, APM will connect directly to Citrix infrastructure and patch the ICA for you. CSG is not mandatory in that case. There is only one check box to check in Virtual Server.
Please contact your local F5 representative (F5 staff or partner) in order to be advices locally.
Regards, Matt
- DeepakK_154002
Thank yo so much for your help.
What is CSG????
- DeepakK_154002
What is CSG????
- Matt_Dierick
Employee
Citrix Secure Gateway. Can be used as ICA proxy. CSG publish your StoreFront and proxy ICA. LTM can be used just to load balance CSG.
Be careful regarding the persistance on LTM.
