Rupesh_M's avatar
Rupesh_M
Feb 13, 2014
Cisco ACS compataible versions for BIG IP 11.4.1 with Hot Fix 2
We are planning to integrate F5 with Cisco ACS (TACACS) for administration purpose, where different user groups will have access to specific partition created on F5. What are the compataible Cisco ACS versions with BIG IP 11.4.1 ?
  • Hamish's avatar
    Hamish
    I'm not aware of any that are in-compatible... I run ACS 5.something at the moment... Works fine... I WAS running 4.1 and 4.0 last year (But with 11.3 and 11.2.1 of BigIP) and that worked fine too...
    Pretty much anything that does TACACS, TACACS+ or RADIUS should be fine...
    H
