pjcampbell_7243's avatar
Apr 13, 2015
Chrome: Your connection is encrypted with obsolete cryptography with 10.2.4HF11 LTM
If you double click on the "lock" icon, Chrome says:
Your connection to (mysite.com) is encrypted with obsolete cryptography.The connection uses TLS 1.2.The connection is encrypted using AES_128_CBC with SHA1 for message authentication and RSA as the key exchange mechanism.
What part of this is considered obsolete? Is this an issue with the cert or the ciphers?
Please note that this site passes SHA2 checks such as "SSLlabs.com" and https://shaaaaaaaaaaaaa.com/. However, the CSR was generated with Signature Algorithm: sha1WithRSAEncryption. The certificate issued from CA with Signature Algorithm: sha256WithRSAEncryption. I don't think starting from scratch with a SHA2 CSR key matters because the cert was issued with sha256.
Also, if I terminate the connection on a Windows 2012 server, rather than on LTM, the obsolete message goes away and it shows a different cipher and key exchange mechanism which makes me think it is only cipher issue. I'm using the following NATIVE ciphers that pass SSLLAbs tests (score A-) as follows:
!SSLv3:!SSLv2:ALL:!DES-CBC-SHA:!DH:!ADH:!EDH:!EXPORT:!RC4-SHA:!RC4-MD5:@SPEED
I don't think enabling non-NATIVE ciphers is a good idea due to limited available CPU cycles. Is this something I should just leave alone until we upgrade to 11?
  • I have the same message with some of my sites. I am also using a SHA256 cert, but it was generated with a sha256 csr. I am preferring strong cipher suites and ECDHE ciphers. So my message reads "AES_256_CBC with SHA1 for message authentication and ECDHE_RSA as the key exchange mechanism." I will research with our security team and see if I can get an answer.
  • can you try to remove sha1 in ciphers (:!SHA1)?
    [root@ve11c:Active:In Sync] config  tmm --clientcipher '!SSLv3:!SSLv2:ALL:!DES-CBC-SHA:!DH:!ADH:!EDH:!EXPORT:!RC4-SHA:!RC4-MD5:@SPEED:!SHA1'
           ID  SUITE                            BITS PROT    METHOD  CIPHER  MAC     KEYX
     0: 49200  ECDHE-RSA-AES256-GCM-SHA384      256  TLS1.2  Native  AES-GCM  SHA384  ECDHE_RSA
     1: 49196  ECDHE-ECDSA-AES256-GCM-SHA384    256  TLS1.2  Native  AES-GCM  SHA384  ECDHE_ECDSA
     2: 49192  ECDHE-RSA-AES256-SHA384          256  TLS1.2  Native  AES     SHA384  ECDHE_RSA
     3: 49188  ECDHE-ECDSA-AES256-SHA384        256  TLS1.2  Native  AES     SHA384  ECDHE_ECDSA
     4:   163  DHE-DSS-AES256-GCM-SHA384        256  TLS1.2  Native  AES-GCM  SHA384  DHE/DSS
     5:   106  DHE-DSS-AES256-SHA256            256  TLS1.2  Native  AES     SHA256  DHE/DSS
     6: 49202  ECDH-RSA-AES256-GCM-SHA384       256  TLS1.2  Native  AES-GCM  SHA384  ECDH_RSA
     7: 49198  ECDH-ECDSA-AES256-GCM-SHA384     256  TLS1.2  Native  AES-GCM  SHA384  ECDH_ECDSA
     8: 49194  ECDH-RSA-AES256-SHA384           256  TLS1.2  Native  AES     SHA384  ECDH_RSA
     9: 49190  ECDH-ECDSA-AES256-SHA384         256  TLS1.2  Native  AES     SHA384  ECDH_ECDSA
    10:   157  AES256-GCM-SHA384                256  TLS1.2  Native  AES-GCM  SHA384  RSA
    11:    61  AES256-SHA256                    256  TLS1.2  Native  AES     SHA256  RSA
    12: 49199  ECDHE-RSA-AES128-GCM-SHA256      128  TLS1.2  Native  AES-GCM  SHA256  ECDHE_RSA
    13: 49195  ECDHE-ECDSA-AES128-GCM-SHA256    128  TLS1.2  Native  AES-GCM  SHA256  ECDHE_ECDSA
    14: 49191  ECDHE-RSA-AES128-SHA256          128  TLS1.2  Native  AES     SHA256  ECDHE_RSA
    15: 49187  ECDHE-ECDSA-AES128-SHA256        128  TLS1.2  Native  AES     SHA256  ECDHE_ECDSA
    16:   162  DHE-DSS-AES128-GCM-SHA256        128  TLS1.2  Native  AES-GCM  SHA256  DHE/DSS
    17:    64  DHE-DSS-AES128-SHA256            128  TLS1.2  Native  AES     SHA256  DHE/DSS
    18: 49201  ECDH-RSA-AES128-GCM-SHA256       128  TLS1.2  Native  AES-GCM  SHA256  ECDH_RSA
    19: 49197  ECDH-ECDSA-AES128-GCM-SHA256     128  TLS1.2  Native  AES-GCM  SHA256  ECDH_ECDSA
    20: 49193  ECDH-RSA-AES128-SHA256           128  TLS1.2  Native  AES     SHA256  ECDH_RSA
    21: 49189  ECDH-ECDSA-AES128-SHA256         128  TLS1.2  Native  AES     SHA256  ECDH_ECDSA
    22:   156  AES128-GCM-SHA256                128  TLS1.2  Native  AES-GCM  SHA256  RSA
    23:    60  AES128-SHA256                    128  TLS1.2  Native  AES     SHA256  RSA
