William_Murphy1
Nov 17, 2006choosing pool based on port in HOST part of HTTP header
newbie here again but attempting some of this stuff anyway.
Trying to write an irule where the pool is decided by what is in the HTTP Header(i.e. HOST: george.george.net:8002)
The request will come with 3 possible ports 8002,8003,8004.
This is what i have written. I have left MMF_pool8002 to last because i want anything that doesnt match the 8003 or 8004 to go to this pool(i.e. MMF_pool8002).
Am I close? Or any tips
set redirectPort [getfield [HTTP::host] ":" 2]
if { $redirectPort equals "8003" }{
pool 8003
}else if {$redirectPort equals "8004" }{
pool pool8004
pool pool8002
Please help man in desparation!
- hoolio
Is the rule working? It looks functionally correct. The only question I have is: is the field you're saving from the host header correct? Try logging the value you get for redirectport and checking the /var/log/ltm log file to verify it's what you expect.
log local0. "port: $redirectPort"
pool 8003
pool pool8004
pool pool8002
Aaron - William_Murphy1
Hi aron,
I have not tested it yet but put it together. The line i am looking to manipluate in the http header looks like this.
"Host: george.george.net:8002"
I need to extract the port from this to determine pool.
What u think?
Will - hoolio
Yep, that works:
log output...
Host header: 172.29.0.219:80 getfield result: 80
Aaron
