Skuba_85554's avatar
Skuba_85554
Feb 05, 2010
choosing persistence method
hi
i'm hoping someone can help me with this irule...
i have a virtual server which requires 2 different types of persistence depending on where the user is coming from. for example, if the user is on the 192.168.0.0/24 network they need to use cookie persistence, but everyone else should use source address affinity
it sounds pretty simple, but any advice would be appreciated
thanks
  • hoolio's avatar
    hoolio
    Hi Skuba,
    You can use the persist command (Click here) to specify a persistence method from an iRule:
     when CLIENT_ACCEPTED {
         Check the client IP
        if {[IP::addr [IP::client_addr] equals 192.168.0.0/16]}{
            Use session cookie persistence
           persist cookie insert "my_persist_cookie" 0
            Use source address persistence with a /24 mask and 1 hour timeout
           persist source_addr mask 255.255.255.0 3600
    Aaron
  • thanks hoolio
    you may find my post interesting re: the java error in the advanced design/config forum
    cheers!
