Matt_Mueller_10's avatar
Matt_Mueller_10
Nov 03, 2006
Checking site by using Login
Is there an iRule that would work in tandom with a Health Monitor to check a site by testing a login and then if that fails it would force the priority grouping to switch to the other Node?
Any help is much appreciated.
  • Colin_Walker_12's avatar
    Colin_Walker_12
    Historic F5 Account
    There isn't currently anything in iRules that will allow you to directly interact with a health monitor (I.E. fire a monitor or directly read the result). You might be able to work around that with multiple pools/monitors, though.
    Colin
