Check the VS port to determine if connection is SSL or not, help me to fix it
when CLIENT_ACCEPTED {
switch [TCP::local_port] { "443" { set proto "https" } default { set proto "http" } }} when HTTP_RESPONSE { set chk_cookies [HTTP::cookie names] foreach cookie $chk_cookies { Rewrite Cookies to ensure the version is Cookie version is correct set cookie_value [HTTP::cookie $cookie] HTTP::cookie remove $cookie HTTP::cookie insert name $cookie value $cookie_value path / version 1 Set HttpOnly for all cookies HTTP::cookie httponly $cookie enable Set Secure if connection is SSL if {$proto=="https"}{ HTTP::cookie secure $cookie enable } }}
Hi jaiAdityaSingla,
I would change the code to...
when CLIENT_ACCEPTED { Check the VS port to determine if connection is SSL or not if { [TCP::local_port] eq "443" } then { set secure_cookie "; Secure" } else { set secure_cookie "" } } when HTTP_RESPONSE { foreach temp(cookie) [HTTP::cookie names] { Rewrite Cookies to ensure the version is Cookie version is correct set temp(cookie_value) [HTTP::cookie $cookie] HTTP::cookie remove $cookie HTTP::header insert Set-Cookie "$temp(cookie)=\"$temp(cookie_value)\"; Version=1; HttpOnly$secure_cookie; Path=/" } }Note1: The code would insert a raw Set-Cookie header, with precomputed cookie options.
Note2: The "; Secure" option is getting substituted using the results of the CLIENT_ACCEPTED event.
Cheers, Kai
