Joe_47002's avatar
Joe_47002
May 07, 2012
Check for Device Peer
Do anyone know how to check and see if a device has a peer or not?
Thanks,
  • hoolio's avatar
    hoolio
    Hi Joe,
    You can check the failover.isredundant DB key:
    tmsh list sys db failover.isredundant
    or in iControl: https://devcentral.f5.com/Default.aspx?tabid=63&articleType=ArticleView&articleId=196
    Aaron
  • Ok. Thanks that helped.
    Say that the device is part of a redundant pair but there is no actual pair there. The device is just set up to have a redundant pair.
    Would their be a way to check to see if that peer is there or not?
  • I had thought about using the get_list() from iSessionPeerDiscovery and I was thinking that if it returned no list then that means there is no peer there even though the device is set up as a redundant pair.
    What do you think?
