Locian_55321
Jan 09, 2013Check for ActiveSync failed logins using iRules
I need to write an iRule to detect failed logins during ActiveSync authentication, I am new to iRules but I think this can be done by checing the response from the exchange server in th HTTP::Response. Has anyone done this before or know how it can be done.
Regards
Ahmed Adel
- What_Lies_Bene1
Are you able to do a tcpdump to see what a failed login looks like, or alternatively use LiveHTTPHeaders, IEHeaders, HTTPWatch or something similar at the browser to inspect what comes back?
Once we understand what a failure looks like it should be fairly simple to write the iRule. - Chris_Miller
Altostratus
Packet capture is indeed the right place to start. You might be able to do this really easily just by looking at whether there are two consecutive 401/403s. That'd be more efficient than having to look at the response payload.
