RSpangler_17032
Oct 31, 2014Changing timeout settings
Client is requesting that I change the timeout setting on the F5. Client is stating that the F5 is calling the server on behalf of the client before the server can complete what its setup for the client.
Where are these setting located so that I can check/change as needed.
Thank you for your time.
- R_Eastman_13667Historic F5 Account
If you have SSL enabled, try the client\server ssl profile. You question really doesn't describe the full scenario. Are you using performance layer 4 VIP, standard VIP, SSL profiles or access policies?
