Franz-Joseph_Kr
Jul 13, 2006changing keys and certificates on ProfileClient SSL
Hello folks,
I problems changing the keys and certificates on the ProfileClientSSL's.
There is no problem creating a new profile and setting the keys and
certificates via the create interface.
But when I try to change the certification or the key via the set_key_file the key is set to default. The same if I try to change the Certification first.
Am I using the wrong interfaces??
By the way I have the same problems after creating a ServerSSLProfile.
Can any body put me on the right way???
Thanks in advance
Francis
- e_28390
Again, this is a very old post, but no solution was every posted. What are we to do? I don't really want to have to delete and recreate every time I want to change certs. Was the solution every released? - Michael_Yates
I've never heard of this problem before.
What hardware and LTM Version are you running?
