Patrick_McGlyn1
19 years agoChanging between SSL Termination and non-SSL Termination
We have an issue where for one application we want to terminate SSL on the F5 and use cookies persistence only for one client based on the client source IP.
I put together the following irule but it is not working:
We are getting page cannot be displayed.
when CLIENT_ACCEPTED {
if { [IP::addr [IP::client_addr] equals $::client_IP] } {
pool test-http
SSL::profile test-cert
persist cookie
pool test-https
SSL::profile none
persist source_addr 1800
- Colin_Walker_12Historic F5 AccountIf you're going to try to read the packet data, you're going to have to terminate SSL for all connections coming into that VIP. Once you've done so, you'll be able to read the IP address of the client and act accordingly.
Is this how you have things set up? If not, you'll need to make sure you're decrypting all incoming traffic, not trying to do so selectively.
Colin - hoolio
I would think that you could make layer 4 decisions (client and/or server IP and/or port) without decrypting the SSL.
Couldn't you configure a client SSL profile on the VIP, but then disable SSL for all requests but the ones that need decrypting for cookie persistence?
There should be some examples in this forum using SSL::disable (rather than SSL::profile).
Aaron
