Certificates Exchange between Load Balancers
Hello Experts,
While performing Certificates Exchange between Load Balancers, i found below error on LB1: [CheckHandlers.cpp:83 checkDevic] System time on 10.147.146.45 off by 1807 seconds
on both load balancers time zone is same.
Pls help me out here.
BR// Hari
- nathe
Cirrocumulus
Hari,
I've had issues in the past when the time on the Bigip was so out that even when i configured NTP it didn't sync the times as I expected. In that example I had to manually set the time on the Bigip, for that see this askf5 sol
Setting the time and date on the BIG-IP system
And then I used the following asf5 sol to confirm the NTP sync then was working as expected Verifying NTP peer server communications
See if this helps,
N
