Brian_Ceryak_86's avatar
Brian_Ceryak_86
Jan 05, 2007
cert works in 9.1.0 but not 9.1.2
The following code worked in 9.1.0 but not in 9.1.2. The iRule is intended to take a client certificate, base64 encode it, pass it along to the server, and make all kinds of good stuff happen. With the upgrade, however, it "appears" the certificate received at the server does not match the client data that is also passed along. Yes, that's right, it seems as though the client certificate gets swapped with data from another session!
The server makes a decision on what type of client is attaching based on the certificate passed. So let's say certificate A is accompanied by a username and department, and certificate B with a username, department, and address. Certificate A has, and not in all cases, data that's only present with CertB and vise versa. Like I said, worked quite well in 9.1.0 but not 9.1.2. Any help is appreciated.
when CLIENTSSL_CLIENTCERT {
Put the certificate in the session
session add ssl [SSL::sessionid] [SSL::cert 0] 180
Get the certificate from the session
set id [SSL::sessionid]
set cert [session lookup ssl $id]
set clientip [IP::remote_addr]
if { $cert ne ""} {
log "ClientIP:$clientip | Status: Success| subject: $cert"
session delete ssl $id
log "ClientIP:$clientip | Status: NoCert| id:none"
log "reject"
reject
return
HTTP::header insert X.509 [b64encode $cert]
HTTP::header insert SSLClientCertSubject [X509::subject $cert]
HTTP::header insert SSLClientSerialNumber [X509::serial_number $cert]
HTTP::header insert ClientIP [IP::remote_addr]
log "Inserting HTTP header ClientCert: $cert"
  • Deb_Allen_18's avatar
    Deb_Allen_18
    Historic F5 Account
    There are a number of other posts on this forum indicating that some issues arose with SSL::cert commands post-9.1.0... From what I remember, they were specific to 9.1 -> 9.2 upgrades, and I don't remember any mention of cross-contamination of user data, either.
    I'd recommend opening a Support case with a tcpdump of the offending traffic.
    /deb
