DM_5174's avatar
DM_5174
Nov 09, 2007
case-sensitive URL redirection - Code conversion
Hi all,
I have created the iRule below with the help of users on this forum in version 4.x, however we also have LBs with version 9.x. Please help me in converting this to version 9.x?
Basically when a someone connects using the URL "http://www.primarysite.com" they get routed to the main page, however, when they enter "home" after the FQDN, they need to get routed to "https://www.secondarysite.com/secure". The "home" needs to be case-insensitive, where it does not matter if they enter it in upper or lower case letters or even a combo, i.e. "hOmE", the result should be that they get routed to "https://www.secondarysite.com/secure/".
if (http_host == "www.primarysite.com" and http_uri matches_regex "/[hH][oO][mM][eE]")
redirect to "https://www.secondarysite.com/secure/"
else {
use pool APACHE_WEB_SERVERS
Thanks all!
  • In 9.x iRules, string case is a lot easier to manage with the help of the TCL string command.
    This should work for you.
      if { ([HTTP::host] equals "www.primarysite.com") && ([string tolower [HTTP::uri]] equals "/home") } {
        HTTP::redirect "https://www.secondarysite/secure/"
    Or, better yet, if you have APACHE_WEB_SERVERS as the default pool within the Virtual Server, you can omit the else clause:
    Keep in mind that you can also use the "starts_with" operator in the HTTP::uri comarison if you want to match all URIs that, well, start with "/home" (ie, /home/one, /home/two, ...)
    Let me know if this doesn't work for you...
    -Joe
