Capturing HTTP Header Info
Please help me out in capturing the HTTP header info when a server is sending data to external client through F5.
Sample info:
content-length:2756
-----------------------------B8C4CFF62AF14 Content-Disposition: form-data; name="from"
111111111 -----------------------------B8C4CFF62AF14 Content-Disposition: form-data; name="to"
Thanks,
Sekhar
- THi
Depends on what you want to get and use the header data for. You could use an iRule to capture the headers from the server response, for example:
when HTTP_RESPONSE { foreach hdr [HTTP::header names] { log local0. "HTTP Header : $hdr = [HTTP::header values $hdr]" } }will produce log lines in /var/log/ltm, similar like this:
Mar 25 22:18:19 apmlab1 info tmm1[11675]: Rule /timo/test_hdr_iRule : HTTP Header : Content-Length = 1293 Mar 25 22:18:40 apmlab1 info tmm1[11675]: Rule /timo/test_hdr_iRule : HTTP Header : Content-Type = text/html Mar 25 22:18:40 apmlab1 info tmm1[11675]: Rule /timo/test_hdr_iRule : HTTP Header : Content-Encoding = gzip Mar 25 22:18:40 apmlab1 info tmm1[11675]: Rule /timo/test_hdr_iRule : HTTP Header : Last-Modified = {Fri, 10 Feb 2012 06:48:40 GMT} Mar 25 22:18:40 apmlab1 info tmm1[11675]: Rule /timo/test_hdr_iRule : HTTP Header : Accept-Ranges = bytes Mar 25 22:18:40 apmlab1 info tmm1[11675]: Rule /timo/test_hdr_iRule : HTTP Header : ETag = {"094905c0e7cc1:0"} Mar 25 22:18:40 apmlab1 info tmm1[11675]: Rule /timo/test_hdr_iRule : HTTP Header : Vary = Accept-Encoding Mar 25 22:18:40 apmlab1 info tmm1[11675]: Rule /timo/test_hdr_iRule : HTTP Header : Server = Microsoft-IIS/7.0 Mar 25 22:18:40 apmlab1 info tmm1[11675]: Rule /timo/test_hdr_iRule : HTTP Header : X-Powered-By = ASP.NET Mar 25 22:18:40 apmlab1 info tmm1[11675]: Rule /timo/test_hdr_iRule : HTTP Header : Date = {Wed, 25 Mar 2015 20:18:40 GMT}This is just for reference, so modify to suit your needs and attach your iRule to your virtual server as a resource in addition to the server pool.
Note that the foreach -loop will produce multiple occurrences of same log line if there are multiple occurrences of the same header name. HTTP::header values -command will list all values of the same header name in this case.
The easiest way is to assign a HTTP profile to your virtual server so you can make use of the HTTP parser and helper commands. Here's a CodeShare entry that logs all request and response headers in an HTTP connection
https://devcentral.f5.com/wiki/iRules.LogHttpHeaders.ashx
If you can't use an HTTP profile, you'll need to use the TCP::payload command to get the full content and then write some string processing to pull the values out.
-Joe
