Aditya_Mehra
Cirrus
7 years agoCan we add a variable reference in a Send String via iApp
I have an application running via an iApp. I need to add a https monitor to it.
Now the thing is the fqdn has over 40 ips, so wanted to know if we can add a variable reference in the send string, tried the below but gives an error.I tried using a variable dest1 and tried to call it in the send string but it does not take the template.
set dest1 \[ lindex \[ RESOLV::lookup @$::dns_recursor -a $::fqdn__dns \] 0 \]
proc create_monitor { } {
set monitor_type "https"
set monitor_name "external_${tmsh::app_name}-monitor"
set monitor_interval "5"
set monitor_timeout "16"
set send {"GET / HTTP/1.1"}
append send {"\n\n\r\n"}
set destination /$dest1
tmsh::create / ltm monitor $monitor_type $monitor_name interval $monitor_interval timeout $monitor_timeout send $send destination $destination
can anyone put some light on this.
Thanks, Aditya
- Hamish
Cirrocumulus
In LTM? You're load balancing an app with 40x RR DNS records?
Why?
