norrtom_376408's avatar
norrtom_376408
7 years ago
Can someone help me with iRule redirects?
Hi All!
I am new to F5 and iRules. I'm helping out a client of mine to do redirections.
I understand that if I want to redirect several URL's from an old domain to a new one, i will do as this:
 if { [string tolower [HTTP::host]] eq "www.old-example.com" and [HTTP::path] eq "/my-old-path/page-y" } {
   HTTP::respond 301 Location "https://www.new-example.com/new-path/page-x"
       if { [string tolower [HTTP::host]] eq "www.old-example.com" and [HTTP::path] eq "/my-old-path-2/page-zz" } {
   HTTP::respond 301 Location "https://www.new-example.com/new-path-2/page-zzy"
             if { [string tolower [HTTP::host]] eq "www.old-example.com" and [HTTP::path] eq "/my-old-path-n/old-page-n" } {
   HTTP::respond 301 Location "https://www.new-example.com/new-path-n/new-page-n"
Can some of you experts out there confirm that the rules above are correct for simple redirections?
Since I will also need to do wildcard redirections as in redirected to , can you help me out with a basic redirect rule for regex redirections?
The wildcard redirections will always have some numbers in the end (page) that change, but else it will always be a quite static slug. Can you help me?
Thank you so much for your time!
Br, Tom
  • Hi Tom,
    Your iRule looks ok and would do the job but there's a bit of repetition. I would check the host header first and do it once, then use a switch statement for all your static redirects. As for your 'wildcard' redirect, you can extract the numbers using
    getfield
    and simply add it as a variable to the end of your redirect.
        set newHost "www.new-example.com"
        if {[string tolower [HTTP::host]] eq "www.old-example.com"} {
           switch -glob [string tolower [HTTP::uri]] {
               "/my-old-path/page-y" {
                   HTTP::respond 301 Location "https://${newHost}/new-path/page-x"
               "/my-old-path-2/page-zz" {
                   HTTP::respond 301 Location "https://${newHost}/new-path-2/page-zzy"
               "/my-old-path-n/old-page-n" {
                   HTTP::respond 301 Location "https://${newHost}/new-path-n/new-page-n"
               "/the/old/slug/*" {
                    set numbers [getfield [HTTP::uri] / 5]
                    HTTP::respond 301 Location "https://${newHost}/my/new/url/$numbers"
    Let me know how you get on.
    Lee
