yosry92_331999's avatar
yosry92_331999
Dec 27, 2017
can i hide encoded json/xml parameter value in body?
i want to see json/xml parameter value that encoded in json/xml data so i want f5 to decode it first then i will apply sensitive data (parameter) to it .
  • You can get the ASM to interpret JSON parameters as sensitive, but I would suggest you only do so on 13.1.0 or later. This can cause unintended problems on versions 11 or 12.
