Can a Active device UCS works for Standby unit.
Hello All,
I have a situation where my standby device has a issue and needs to be replaced, can a active device UCS be used in the new replaed standby device ?
What additional configuration changes may need to make in the standby unit , to make it similar as existing before the device replaced.
Thanks... Sam
- shaggy
usually no, as the self-IP addresses, hostname, device-cert, etc. will be different.
check out SOL13551: Configuring a replacement BIG-IP device after an RMA when no UCS archive is available - https://support.f5.com/kb/en-us/solutions/public/13000/500/sol13551.html
in a nutshell:
- Configure networking options for the management interface
- Activate the license for the new hardware
- Configure networking options for the TMM interfaces
- Set Device Connectivity options for the replacement BIG-IP device
- Re-configure the existing Device Trust and Device Group on an authority device
- Sync from active-to-standby
- Mahmoud_Eldeeb_
No.
