can 2013 and 2010 exchange coexist on load balancer
dear all, we just deploy exchange 2013 and we have exchange 2010 existing in place with F5 load balancing the 2010 cas can they coexist with no issues and re directions bcs user mailbox on 2013 cannot connect to outlook client owa and mobile sync work fine.
- mikeshimkus_111Historic F5 Account
Hi, when Outlook clients cannot connect to a 2013 mailbox, do you see a connection attempt in the virtual server and pool statistics?
Have you deployed APM?
Which protocol are the Outlook clients using (RPC over HTTP or MAPI over HTTP)?
Have you tried using Wireshark or tcpdump to look at the traffic on both sides of the BIG-IP when this is happening?
thanks
