Reza_76713
Mar 17, 2009bypass ASM based on protocol usage
Hey guys,
How can I bypass ASM?
I have a server pool reached via http and Https protocols.
I will to enable ASM on http request and disable ASM on Https request.
What is the best possible solution here?
Thx
- hoolio
I think it would be simplest to configure two separate VIPs: one for HTTP with an ASM-enabled HTTP class and a second for HTTPS with no HTTP class. This would ensure that only HTTP requests are validated by ASM.
Aaron - Reza_76713
Cool, it works, thx
