Building QA F5 from production
We are currently building out a new F5 with the same software and configuration settings as our production. Is there way to edit a saved copy of our production F5 to change ip addresses to the addresses that will be used in our QA environment. This would eliminate the possibility of a duplicate ip address and causing impact to the production environment. We are looking to recreate a production and need to ensure we have the same settings except for the addresses to test and resolve the issues.
thanks
- JRahm
Admin
You can export your configuration in single line format and then update IPs before loading into QA device:
tmsh save sys config one-line file /var/tmp/myconfig.txt
