player_72606's avatar
player_72606
Sep 16, 2010
bring down VS using iRule
Hi all,
i need to bring down/offline VS and drop the icmp echo-request and echo-reply when it's pool member are down.
any ideas how to?
  • George_Watkins_'s avatar
    George_Watkins_
    Historic F5 Account
    Hi player,
    I think I may have answered this question in another forum, but I'll give it another go. As long as a virtual server is configured, the LTM will continue to answer echo-requests regardless of the state of the assigned pool. The only way (that I know of) to stop all traffic destined for a virtual address is to use the 'b virtual address arp disable' command. For instance, if you wanted to disable all traffic for virtual address 10.0.0.1 you'd issue the command: b virtual address 10.0.0.1 arp disable. Then enable it again whenever it is needed.
    A tangential use case, but I've use this for migrating virtuals between physical boxes.
    -George
  • Hey Guys, this is a tough one, I've thought about it in the past but couldn't come up with anything.. I can't find doc that references ICMP in the command list, and I'm not sure what event it would fall under because ICMP, even though still at the network layer, is a separate protocol than IP.... so I don't see a event that would support it.. Like you mention it seems to be a fundamental function of a VS... Here's an old post talking about the same issue... http://devcentral.f5.com/Forums/tabid/1082223/asg/50/showtab/groupforums/afv/topic/aff/5/aft/3591/Default.aspx Some interesting ideas.... Can you invoke a bigpipe command or script from an irule? If so, you could use the arp idea in that post.. I'm not to sure about deleting the VS.. as how would you add it back in?
  • well, the only thing to do is to disable the ARP on the VS,
    disable ARP upon down/offline pool members
    enable ARP upon online pool members
    the issue here is how to automate it , some kind of a monitor is needed here also...
  • Hamish's avatar
    Hamish
    It would really have to be external... You could have something like nagios watch the pool status (Could be via traps, but they're not guaranteed, so you really want to poll as well to catch missing traps), and when it goes down, run a small script that uses an iControl call (In perl or whatever) to down the VS... Then when it comes back up, re-enable it...
    H
