Deep_287674's avatar
Deep_287674
9 years ago
Botnet Mitigation if traffic initiated from inside to outside
Hi All,
How can we mitigate botnet from inside, suppose if the traffic is initiated by Application server to the Internet. Can we mitigate ?
  • Will the Captha is good option ...if you have any document plz share related to inside to internet Botnet prevention.
  • Hi Deepak,
    With what modules ? If a Botnet appeared on your internal Network, that's slightly worrying and hopefully would be picked up by a security function within your business.
    If your specifically concerned about a certain application subnet, how does it currently access the internet ? Does it need to access the internet? If its just for an application, can you restrict the IP's it gets to, websites etc etc. (You're bordering on WebProxy territory here)
    Could you deploy ASM and look at the application traffic, learn what is "Normal" and log/drop things that aren't ?
    From the information you've provided, its very difficult to answer the question. But hopefully the above will help direct you down the right path.
    • Deep_287674's avatar
      Deep_287674
      We have deployed Big Ip AFM/ASM and done L4 and L7 DDOS profiling.
      But one Bluecoat proxy is there , they want F5 ASM acting as a proxy and traffic initiated from inside proxy to Internet through F5 ASM should work for software up-gradation like stuff. In this scenario can we mitigate any Bot from inside, As before implementing we need solution for this.
    • IainThomson85_1's avatar
      IainThomson85_1
      We're "solutionising" different products here.
      You've stated you want to mitigate a botnet potentially accessing external resources (Internet)
      In this instance your Bluecoat (in my opinion) is in a far better position to lock down access based on Source IP address. You can also do things on the Bluecoat SG like enabling Threat Detection amongst other features.
      From the F5 perspective. You can apply an ASM policy to a VIP which is controlled/admistered to applications you want the service to access.
      Deep_287674
      We would configure forwarding virtual server from inside to outside.
      SourceProxyIP--> Destination any any--> SNAT to VIP
      In this scenario u mean let the proxy do the botnet protection . Then F5 will by pass the traffic only to the internet.
