booting issue after a fail over
Hi Dears ,
After a fail over one of my F5 loadbalancers (ltm 1600 model) doesn't boot completely since , i can ping its IP (ssh and telnet ports are opened before) but its web GUI doesn't load and some of services don't work properly .wherein i had tested HA test before and it worked completely . would you please guide me to solve this issue . OS version 10.2.4
- nitass_89166
Noctilucent
for web gui issue, you may check httpd and tomcat logs.
for service issue, you may try tcpdump.
sol411: Overview of packet tracing with the tcpdump utility
https://support.f5.com/kb/en-us/solutions/public/0000/400/sol411.html- aliakbargholami
thank you nitass i will check it and inform you about resault
- nitass
Employee
- kunjan_118660
Cumulonimbus
You can try '
' on cli to see if any error while it startup.tmsh load sys config- aliakbargholami
thank you Kunjan i will check it and inform you about resault
- kunjan
You can try '
