wick54's avatar
wick54
Sep 25, 2019
Block URIs and forward traffic 2 pools on same VIP
Hi Team,
We currently have a requirement for single VIP to service 2 URLs and also to check URI and only allow 4 specific URIs.
I currently have it as 2 different VIPs with 2 pool and have an irule attached to it block URIs as below which is working as expected to allow specific URIs
              switch -glob [HTTP::uri]]
                             "/abc*" -
                             "/bcd*" -
                             "/efg*" -
                             "/cvy" -
                             default
                                            drop
I have prepared another irule which can be used to pass the traffic specific pool depending on the hostname.
set hostname [string tolower [HTTP::host]]
  switch $hostname {
    "abc.com" {
      pool abc_pool
    default {
       do nothing use the pool for VIP
Can I combine these irules to achieve which i wanted or would it be easier to use ltm policy?
  • You can combined two irule in Single iRule but above requirement is not clear.
    Just put the dummy Application name and URL ==> Redirect Pool name
    example :
    URL ==>> www.abc.com and URI==> /pqr or /xyz ==> redirect pool ==> pool_A
    URL ==> www.def.com and URI ==> /sat or /hij ==>> redirect pool ==> Pool_B
    Hope you understand it.
