Block URIs and forward traffic 2 pools on same VIP
Hi Team,
We currently have a requirement for single VIP to host 2 URLs and also check URI and only allow 4 specific URIs.
I currently have it as 2 different VIPs with 2 pool and have an irule attached to it block URIs as below which is working as expected to allow specifc URIs
switch -glob [HTTP::uri]]
"/abc*" -
"/bcd*" -
"/efg*" -
"/cvy" -
default
drop
I have prepared another irule which can be used to pass the traffic specific pool depending on the hostname.
set hostname [string tolower [HTTP::host]]
switch $hostname {
"abc.com" {
pool abc_pool
default {
do nothing use the pool for VIP
Can I combine these irules to achieve which i wanted or would it be easier to use ltm policy?
Hi wick54,
Can you try this iRule?
when HTTP_REQUEST { switch -glob [string tolower [HTTP::uri]] { "/abc*" - "/bcd*" - "/efg*" - "/cvy*" { switch -glob [string tolower [HTTP::host]] { "abc.com" { pool abc_pool } "xyz.com" { pool xyz_pool } default { # do nothing use the pool for VIP # or drop } } } default { drop } } }
