Block SSL V3 Traffic.
Hi Team,
When i did external scan of URL. I found my site is vulnerable with SSLV3. Can any one help me to block it.
This server may be vulnerable: SSLv3 is enabled -->This server uses SSLv3, which is a vulnerable protocol. Disable SSLv3 and use TLS 1.0 or higher.
Browser compatibility is at risk --> Modern browsers may not trust certificates signed using a SHA-1 hash algorithm. Contact your Certificate Authority to replace SHA-1 certificates installed on the server with SHA-256 certificates.
Your server cannot be scanned for the Poodle (TLS) vulnerability --> Try the certificate installation check again.
Thank you
- nathe
Cirrocumulus
Samir,
Couple of ways - this assumes you have a client ssl profile on the virtual server and you are terminating SSL at the bigip (even if you are re-encrypting to the pool members).
- Configure the Ciphers section. If it's currently DEFAULT then change to DEFAULT:!SSLv3
- Configure the client ssl Options List. You should see a "No SSLv3" item you can enable.
Hope this helps,
N
