Nfordhk_66801's avatar
Nfordhk_66801
Jul 13, 2015
BIGIP Traffic Flow
I know this is a simple question but I wanted to verify I understood BIGIP functionality.
When a client accesses a VIP (without SNAT), and that VIP calls its pool (in-line configuration). A pool member then needs to access a database not on the F5. At that point is it mandated the connection passes back through the F5 before accessing the DB, or can it go directly to the DB.
In my understanding, it must pass back through F5.
  • The pool member can connect directly to the DB provided, of course, that routing and VLAN config allow this. Where are the DB servers located? Same vlan as the pool members?
