BigIP HTTP500 on collections in /mgmt/ltm
Hello,
I am running a F5 BigIP on "BIG-IP 13.1.1.2 Build 0.0.4 Point Release 2". I want to query ressources by REST, which works fine for single ressources, e.g.:
I can ask /mgmt/tm/ltm/virtual/<id> without any problems with HTTP GET, but when I query the collection by asking /mgmt/tm/ltm/ i get an HTTP500 with the following error in log:
WARNING][277904][22 May 2019 07:41:35 UTC][8100/mgmt/shared/resolver/groups ForwarderPassThroughWorker] URI:http://localhost:8100/mgmt/tm/ltm/virtual, Referrer: myip..., Method:GET, Exception:java.util.concurrent.TimeoutException: remoteSender:10.2.107.29, method:GET
at com.f5.rest.common.RestWorker.logAndFailExpiredOperation(RestWorker.java:3099)
at com.f5.rest.common.RestWorker.checkForExpiredOperations(RestWorker.java:3088)
at com.f5.rest.common.RestServer.checkAndExpirePendingWorkerOperations(RestServer.java:1457)
at com.f5.rest.common.RestServer.access$400(RestServer.java:48)
at com.f5.rest.common.RestServer$4.run(RestServer.java:1430)
at com.f5.rest.common.ScheduleTaskManager$2$1.run(ScheduleTaskManager.java:123)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:473)
at java.util.concurrent.FutureTask.run(FutureTask.java:262)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:178)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:292)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1152)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:622)
at java.lang.Thread.run(Thread.java:748)The same problem applies to the /mgmt/ltm/pool ressource.
Can anyone help me here?
Thanks and regards;)
- Satoshi_Toyosa1Ret. Employee
The error message mentions "Timeout". Is the timestamp of the error 60-70s after you made the request? If so, the system could not handle the large amount of objects in the given time. You may want to use the OData query parameters ($top and $skip) to get a subset of the objects and repeat.
