bigip_device_info errors with - virtual-servers
I am trying to pull an existing description from an existing virtual server using ansible.
I found bigip_device_info but am running into errors.
I have a ansible yaml file facts.yml:
name: Collect BIG-IP information
bigip_device_info:
provider: "{{ provider }}"
gather_subset:
#- virtual-addresses
#- ltm-pools
- virtual-servers
register: bigip_device_info
delegate_to: localhost
virtual-addresses & ltm-pools both work and return valid information. However virtual-servers always crashes.
Will someone please shed some light on this issue and let me know if the syntax is incorrect, is there a bug, etc?
Following is the debug error messages with virtual-servers enabled in the yaml file:
task path: /home/mboster/cloud-infrastructure/cloudops/infrastructure/network/ansible/waf/roles/mq_deployment/tasks/mq_facts.yml:1
<localhost> connection transport is rest
<localhost> ESTABLISH LOCAL CONNECTION FOR USER: mboster
<localhost> EXEC /bin/sh -c 'echo ~mboster && sleep 0'
<localhost> EXEC /bin/sh -c '( umask 77 && mkdir -p "` echo /home/mboster/.ansible/tmp/ansible-tmp-1591302659.2270741-189006385395292 `" && echo ansible-tmp-1591302659.2270741-189006385395292="` echo /home/mboster/.ansible/tmp/ansible-tmp-1591302659.2270741-189006385395292 `" ) && sleep 0'
Using module file /usr/local/lib/python3.6/site-packages/ansible/modules/network/f5/bigip_device_info.py
<localhost> PUT /home/mboster/.ansible/tmp/ansible-local-73580ev1lcolg/tmphdp8u7ap TO /home/mboster/.ansible/tmp/ansible-tmp-1591302659.2270741-189006385395292/AnsiballZ_bigip_device_info.py
<localhost> EXEC /bin/sh -c 'chmod u+x /home/mboster/.ansible/tmp/ansible-tmp-1591302659.2270741-189006385395292/ /home/mboster/.ansible/tmp/ansible-tmp-1591302659.2270741-189006385395292/AnsiballZ_bigip_device_info.py && sleep 0'
<localhost> EXEC /bin/sh -c '/usr/bin/python3 /home/mboster/.ansible/tmp/ansible-tmp-1591302659.2270741-189006385395292/AnsiballZ_bigip_device_info.py && sleep 0'
<localhost> EXEC /bin/sh -c 'rm -f -r /home/mboster/.ansible/tmp/ansible-tmp-1591302659.2270741-189006385395292/ > /dev/null 2>&1 && sleep 0'
The full traceback is:
File "/tmp/ansible_bigip_device_info_payload_b_s1s_gf/ansible_bigip_device_info_payload.zip/ansible/modules/network/f5/bigip_device_info.py", line 16259, in main
File "/tmp/ansible_bigip_device_info_payload_b_s1s_gf/ansible_bigip_device_info_payload.zip/ansible/modules/network/f5/bigip_device_info.py", line 15999, in exec_module
File "/tmp/ansible_bigip_device_info_payload_b_s1s_gf/ansible_bigip_device_info_payload.zip/ansible/modules/network/f5/bigip_device_info.py", line 16078, in execute_managers
File "/tmp/ansible_bigip_device_info_payload_b_s1s_gf/ansible_bigip_device_info_payload.zip/ansible/modules/network/f5/bigip_device_info.py", line 15674, in exec_module
File "/tmp/ansible_bigip_device_info_payload_b_s1s_gf/ansible_bigip_device_info_payload.zip/ansible/modules/network/f5/bigip_device_info.py", line 15682, in _exec_module
File "/tmp/ansible_bigip_device_info_payload_b_s1s_gf/ansible_bigip_device_info_payload.zip/ansible/modules/network/f5/bigip_device_info.py", line 7092, in to_return
File "/tmp/ansible_bigip_device_info_payload_b_s1s_gf/ansible_bigip_device_info_payload.zip/ansible/modules/network/f5/bigip_device_info.py", line 15253, in destination_address
File "/tmp/ansible_bigip_device_info_payload_b_s1s_gf/ansible_bigip_device_info_payload.zip/ansible/modules/network/f5/bigip_device_info.py", line 15634, in destination_tuple
fatal: [ftbc-f5-dev1 -> localhost]: FAILED! => {
"changed": false,
"invocation": {
"module_args": {
"gather_subset": [
"virtual-servers"
"provider": {
"auth_provider": null,
"password": "VALUE_SPECIFIED_IN_NO_LOG_PARAMETER",
"server": "ftbc-f5-dev1",
"server_port": 443,
"ssh_keyfile": null,
"timeout": null,
"transport": "rest",
"user": "mboster",
"validate_certs": false
"msg": "The provided destination is not a valid IP address"
- Sachin-Garg
Altostratus
Can you please share your
BIG-IP software version & Ansible Version & Python version
I can see python3.6
bigip_gather_facts has been deprecated /Removed in Ansible version 2.11 (This module has ben removed in version 2.11. [deprecated])
The bigip_facts module relies on SOAP to communicate with the BIG-IP, and has a large amount of code that does not conform to existing F5 standards.
The bigip_device_info module (Requires BIG-IP software version >= 12) is easier to maintain and use. This module was called bigip_device_facts before Ansible 2.9. The usage did not change.
can you provide the output of curling these two APIs
https://IP_ADDRESS/mgmt/tm/sys/software/image
https://IP_ADDRESS/mgmt/tm/sys/software/hotfix
Please see this section:
"changed": false,
"invocation": {
"module_args": {
"gather_subset": [
"virtual-servers"
"provider": {
"server_port": 443,
"timeout": null,
"user": "mboster",
- this is the error you're receiving?
"msg": "The provided destination is not a valid IP address"}
It Seems that the partition is not striped correctly since the regex doesn't match numbers and your partition name may contains numbers. Can you please share the names of the partitions.
2. validate_certs must be one of: yes,no
validate_certs: False
Can you try the latest version:
Minimum Ansible Version 2.8
https://galaxy.ansible.com/f5devcentral/f5ansible
Try these links
https://github.com/F5Networks/f5-ansible/issues/1124
https://clouddocs.f5.com/training/fas-ansible-workshop-101/1.8-virtual-server-facts.html
https://clouddocs.f5.com/products/orchestration/ansible/devel/modules/bigip_device_facts_module.html
- markbz
Altostratus
ansible --version
ansible 2.9.0
config file = /etc/ansible/ansible.cfg
configured module search path = ['/home/mboster/.ansible/plugins/modules', '/usr/share/ansible/plugins/modules']
ansible python module location = /usr/local/lib/python3.6/site-packages/ansible
executable location = /usr/local/bin/ansible
python version = 3.6.8 (default, Apr 2 2020, 13:34:55) [GCC 4.8.5 20150623 (Red Hat 4.8.5-39)]
[mboster@fthc-ctrl-net1 ~]$ python --version
Python 2.7.5
target partitiion is /Common
list auth partition default-route-domain
auth partition AC-PROD {
default-route-domain 0
auth partition Common {
auth partition test_partition {
see attached png file for image. There isn't any hotfix.
1. Yes that is the error I am receiving
2. validate_certs: no is set in the master_playbook.yml
- markbz
Altostratus
From the master playbook, validate_certs is no, which is where the reported false comes from.
vars:
provider:
password: "{{ password }}"
server: "{{ inventory_hostname }}"
user: "{{ username }}"
validate_certs: no
server_port: 443
- Darius
markbz,
So are you saying that you can take the exact same playbook and change the information in gather_subset and you get an error ONLY when trying to use "virtual-servers"?
This works
... ... gather_subset: - virtual-addresses ... ...but this doesn't?
... ... gather_subset: - virtual-servers ... ... - markbz
Altostratus
Darius,
Yes that is exactly what happens.
using - virtual-servers results in a crash.
- richardgamboac1
I am having the same issue. Did you find any answer?
