datago_205305
Aug 04, 2015bigip.conf won't load due to invalid requested attribute
I inherited a production configuration. The top of bigip.conf is:
datastor {
low water mark 80
high water mark 90
deduplication {}
shell write partition Common
v10 b verify load returns:
The requested attribute (deduplication {) is invalid for 'datastor'.
A similar but different bigip.conf, with the same beginning lines does not return this error. Is this a false positive? Is there a recommended way to troubleshoot?
- DevBabu
Cirrus
what if you remove the lines starting from datastor till deduplication and verify.
