Milan_61890
Mar 05, 2014bigip_base.conf not loading
I have a problem restoring configuration from a .ucs file to a blank v10.2.3 HF1 LTM. The error message says:
Loading the configuration ...
BIGpipe self IP address creation error:
01070277:3: The requested vlan, vlangroup or tunnel (datapriv1) was not found.
WARNING: There were one or more errors detected during installation.
Check the error messages and take the proper actions if needed.
ERROR: UCS installation failed.
I could pin it down to a problem with loading of the bigip_base.conf file. When I simply copy it to /config everything goes ok. May there be a parsing problem with the structure/syntax? After copied the configuration works well.
Thanks in advance!
Here is the file:
mgmt 10.94.248.14 {
netmask 255.255.255.224
mgmt route default inet {
gateway 10.94.248.1
interface 1.1 {
stp disable
interface 1.2 {
stp disable
interface 2.1 {
stp disable
interface 2.2 {
stp disable
stp instance 0 {
vlans {
datapriv1
datapriv2
datapriv3
datapriv4
datapriv5
datapriv6
datapriv7
datapriv8
datapriv9
datapub1
datapub10
datapub13
datapub15
datapub18
datapub2
datapub3
datapub4
datapub5
datapub6
datapub7
datapub8
datapub9
heartbeat
self allow {
default {
tcp ssh
tcp domain
tcp snmp
tcp https
tcp mysql
tcp f5-iquery
udp domain
udp snmp
udp efs
udp cap
udp f5-iquery
proto ospf
shell write partition Common
vlan datapriv1 {
tag 2251
interfaces tagged {
1.1
2.1
vlan datapriv2 {
tag 2252
interfaces tagged {
1.1
2.1
vlan datapriv3 {
tag 2253
interfaces tagged {
1.1
2.1
vlan datapriv4 {
tag 2254
interfaces tagged {
1.1
2.1
vlan datapriv5 {
tag 2255
interfaces tagged {
1.1
2.1
vlan datapriv6 {
tag 2256
interfaces tagged {
1.1
2.1
vlan datapriv7 {
tag 2257
interfaces tagged {
1.1
2.1
vlan datapriv8 {
tag 2258
interfaces tagged {
1.1
2.1
vlan datapriv9 {
tag 2259
interfaces tagged {
1.1
2.1
vlan datapub1 {
tag 2211
interfaces tagged {
1.1
2.1
vlan datapub10 {
tag 2220
interfaces tagged {
1.1
2.1
vlan datapub13 {
tag 2223
interfaces tagged {
1.1
2.1
vlan datapub15 {
tag 2225
interfaces tagged {
1.1
2.1
vlan datapub18 {
tag 2228
interfaces tagged {
1.1
2.1
vlan datapub2 {
tag 2212
interfaces tagged {
1.1
2.1
vlan datapub3 {
tag 2213
interfaces tagged {
1.1
2.1
vlan datapub4 {
tag 2214
interfaces tagged {
1.1
2.1
vlan datapub5 {
tag 2215
interfaces tagged {
1.1
2.1
vlan datapub6 {
tag 2216
interfaces tagged {
1.1
2.1
vlan datapub7 {
tag 2217
interfaces tagged {
1.1
2.1
vlan datapub8 {
tag 2218
interfaces tagged {
1.1
2.1
vlan datapub9 {
tag 2219
interfaces tagged {
1.1
2.1
vlan heartbeat {
tag 2001
interfaces {
1.2
2.2
self 10.94.254.46 {
vlan heartbeat
allow all
self 164.35.160.14 {
vlan datapriv1
allow all
self 164.35.160.46 {
vlan datapriv2
allow all
self 164.35.160.78 {
vlan datapriv3
allow all
self 164.35.160.110 {
vlan datapriv4
allow all
self 164.35.160.142 {
vlan datapriv5
allow all
self 164.35.160.174 {
vlan datapriv6
allow all
self 164.35.160.206 {
vlan datapriv7
allow all
self 164.35.160.238 {
vlan datapriv8
allow all
self 164.35.161.14 {
netmask 255.255.255.0
vlan datapriv9
allow all
self 111.222.32.14 {
vlan datapub1
allow all
self 111.222.32.46 {
vlan datapub2
allow all
self 111.222.32.78 {
vlan datapub3
allow all
self 111.222.32.110 {
vlan datapub4
allow all
self 111.222.32.142 {
vlan datapub5
allow all
self 111.222.32.174 {
vlan datapub6
allow all
self 111.222.32.206 {
vlan datapub7
allow all
self 111.222.32.238 {
vlan datapub8
allow all
self 111.222.33.14 {
vlan datapub9
allow all
self 111.222.34.142 {
vlan datapub10
allow default
self 111.222.34.206 {
vlan datapub13
allow default
self 111.222.35.14 {
vlan datapub15
allow default
self 111.222.36.78 {
vlan datapub18
allow default
failover {
force active enable
force standby disable
unit 2
unicast peer xxx {
dest addr 10.94.254.41
port 1026
source addr 10.94.254.46
snmpd {
syscontact "xxx>"
syslocation "Network Closet 20"
statemirror {
addr 10.94.254.46
peer addr 10.94.254.41
syslog {
remote server {
fwb-pan-lgs1_data {}
fwb-rad-lgs1_data {}
system {
gui setup disable
hostname "hostname.fw.dcom"
just look at the file and perhaps this is normal i find this section odd:
} **shell write partition Common** vlan datapriv1does that really belong there?
