dirome's avatar
dirome
Icon for Cirrus rankCirrus
Oct 16, 2019
big-iq error vlan and load configuration
Hi buddies,
Someone knows what happened with the error in the image? and how resolve it?
  • you can probably resolve it by removing it from the config file. but then again you probably need that VLAN right?
    how did this problem start? did the system crash or lost power or ...?
    in the last cases i would open a support ticket if you can, best let support fix this then start trying yourself.
    • dirome's avatar
      dirome
      Boneyard,
      I don't know how it happen, i tried deleting from the configuration but it even doesn't exist into the configuration, this is an lab environment then i cannot scale to f5 support
      some another idea?
