Marieme's avatar
Marieme
Icon for Cirrus rankCirrus
Nov 22, 2018
BIG IP Virtual Edition 13.1.1 Installation & Configuration
Hello I have some services that i need to published on an intranet. My environement is composed with intranet, firewall, BIG IP virtual Edition, and servers . The layer 3 routing is on the firewall. Below are my questions: do i need to create involved dedicated vlan of applications published? how can i create specific partition on my BIG IP VE? Also how can i configure HA for my cluster devices? Platform is LTM
Thanks in advance for your reply
Marieme
  • Hello Marieme
    Do I need to create involved dedicated vlan of applications published?
    Well this depends on how your network design looks. You can use the BIG-IP in a One-arm mode where your traffic will work in the following way:
    Incoming Traffic
    -> [Firewall] -> [BIG-IP] -> [Firewall] -> [Servers]
    Return Traffic
    -> [Servers] -> [Firewall] -> [BIG-IP] -> [Firewall]
    In this case you are forced to use SNAT in order to translate the source IP address to one that is owned by the BIG-IP device.
    So no, you're not forced to create additional VLANs and have the pool members directly attached to the BIG-IP.
    How can I create specific partition on my BIG IP VE?
    Manual Chapter: Working with Partitions
    Manual Chapter: Creating an Active-Standby Configuration Using the Setup Utility
    I hope this helps! :)
